Thread: Kawasaki TS 650
    Mar 2017
    Norway
    Kawasaki TS 650
    Hi!
    I need a new impeller for my ts 650, should i go for a stock impeller or something else? i also wonder if there is any performance parts for these? anu other things i should do or look for when it has been sitting for 10+ years?
    sorry for my bad english..
    I dream skis sportsfreak29's Avatar
    Oct 2011
    Midland, Tx.
    Re: Kawasaki TS 650
    They're a bit gutless and will never have much top end speed. So go for low end power with a Skat variable pitch in the 8/16 range.
    Ski situation in limbo!
    Special thanks to Chris Newmiller, and Mitchell at M&M Marine!
    Aug 2014
    Re: Kawasaki TS 650
    Sounds correct to me. Open the good Alum grate, get some water in the pump. With a old hull design and 421 lbs dry weight, im thinking 42 mph once the 93 is tuned. Any more, just do a 750 drop. My ZXI was 462 lbs with an 1100 trip.
    '94 Kaw TS
    '93 Kaw TS
    02' Kaw STX-R
    Oct 2011
    Midland, Tx.
    Re: Kawasaki TS 650
    I have 2 stock impellers
