X2 1" 6061 aluminum pump spacers
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
    Shiocton, Wisconsin
    sell or trade for other stuff. 5 available (see post in trade section). PM me if interested, Thanks.pump spacer 3.JPGpump spacer 2.JPGpump spacer.JPG
    Shiocton, Wisconsin
    Re: X2 1" 6061 aluminum pump spacers
    4 pump spacers left. I also have adapters available to install the
    OEM 650 flame arrestor on your SBN44. $34 shipped with SS hardware
    included.
    Got mine this passed weekend. Excellent quality. Giving it a test this Saturday!
    Shiocton, Wisconsin
    3 spacers left.
    Top Dog mx595's Avatar
    Dec 2002
    NH
    Iíll take one. Can you please pm me your Paypal info?
    DIALED IN BY Z-FORCE RACING
    www.zforcemotorsports.com
    I own a few skis that I ride a few times a year...
    PWCToday Newbie catpower's Avatar
    May 2008
    Iowa
    did quick search but not fully understanding how it works on a stock 650 pump. Can someone post a link.
    Shiocton, Wisconsin
    This spacer eliminates the trim system. You bolt the spacer in between the X2 pump
    and a 650SX nozzle. It also allows use of any of the aftermarket nozzles made for
    the 650SX on an X2.
    PWCToday.com Is My Home Away From Home WaveRunner Eagle's Avatar
    Aug 2008
    Gainesville, FL
    I just installed my spacer this weekend. I decided to keep the trim system so I bought two 1" cable extenders from Rhaas. Everything went together super easily and appears to work. I'll hopefully be testing this setup in the Daytona surf in two weeks if I can get the stupid thing to run properly....
    You can see the before and after below. On a stock ski, a lot of the thrust hits the inside of the pump tunnel in a turn. Usually people chop the hull shorter, but I wanted to keep this ski fairly stock. The 1" spacer pushes the nozzle out so it sticks out just past the hull
    edit* - no my seat cover isn't that screwed up, it's not installed in these pictures. I just stretched it over the seat to admire
    Skis:
    1986 X2
    1987 750 X2
    1990 SNSJ
    1994 WB1
    1995 VHP
    Feb 2016
    New Jersey
    Got my spacer today and it looks great. I won't be able to test it until May or June, but you can bet it will be installed for my first ride of 2018.
    May 2008
    Iowa
    [QUOTE=WaveRunner Eagle;4460335]I
    That's a good explanation and I might consider buying one now,. Saves cutting the X2 and keep trim plus use other nozzles. I got it thanks for the photos!
