Pump rebuild, is it difficult? - Page 2
Results 11 to 13 of 13
    charlotte,nc
    Re: Pump rebuild, is it difficult?
    Quote Originally Posted by Yabadabadoo View Post
    Ok, thanks guys. Ya I figured it would be easy, I just didn't want to rip it all apart then realize I need a press or something. I've done motorcycle wheel bearings before, sounds similar. I'll heat up the pump and freeze the bearings, hopefully they'll drop right in.
    Appreciate the help. Cheers
    you dont want to freeze the bearings and heat up the shaft. you want to heat up the inner race of the bearing i wouldnt use anything more than a heat gun for the bearings and freeze the shaft. freezing the shaft will temporarily slightly shrink the shaft and heating up the inner race will temporarily expand the ID. freeze the impeller shaft for 1/2 hour or so then work quickly. youll have about 10 seconds to slide the bearing in place before the heat gets to the impeller shaft and locks it in place. a press is definitely the easiest and best way to remove the old bearings as well as the quickest.
    Aug 2017
    Vancouver Island, Canada
    Ya gotcha, Iin my mind I'm just remembering wheel bearings on my bike you heat the bearing holder (wheel) to expand it, then freeze the bearings to shrink them then they drop right in as the friction fit is on the outer race..... Heat= expand, freeze = shrink.... I'll get er done.... Thanks guys
    charlotte,nc
    which pump are you rebuilding?
