Results 1 to 10 of 13
    Aug 2017
    Vancouver Island, Canada
    Pump rebuild, is it difficult?
    Hi all,
    Never done a pump rebuild. Do I need special tools such as a hydraulic press? Or does the old heat up the holder and freeze the bearing system work?
    Are the old bearings hard to get out?
    I've rebuilt everything else on skis, just never a pump so looking for some insight before I start.
    Thanks in advance
    SE MI
    Re: Pump rebuild, is it difficult?
    A screwdriver at a minimum, I have used sockets and a long bolt to pull the bearings back into position (gently tapping around the perimeter with a screwdriver works too). Simple tools can get the job done, should be a 30 min job if the pump is on the bench already.
    Use heat on the pump to install new bearings. Hand held propane, or map gas torch, and you will need little to no force to install bearings. It is really pretty simple, I am sure you can handle it.
    email watcon@watcon.com
    Please visit our web sites
    Aug 2017
    Ok, thanks guys. Ya I figured it would be easy, I just didn't want to rip it all apart then realize I need a press or something. I've done motorcycle wheel bearings before, sounds similar. I'll heat up the pump and freeze the bearings, hopefully they'll drop right in.
    Appreciate the help. Cheers
    Aug 2010
    Minnesota
    I find that unscrewing the impeller from the shaft might be the hardest part. But in the end it always does pop loose. You need the spline-to-hex tool, or fabricate something with an old driveshaft spline.
    OLDGUY sez..... "The older I get, the better I was !
    Aug 2017
    Quote Originally Posted by OldGuy View Post
    Oh thats actually good news because I have done that before an has the tools for it.....I had an old 440 once I changed the impeller on, man that thing was stuck tight!!!
    PWCToday Newbie Brandon577's Avatar
    Nov 2015
    South East CT
    Yabadabadoo its a fairly easy job, like OldGuy says getting the impeller off is the hardest part! I usually use a flat head screw driver to remove the seals and a hammer and socket to remover the bearing. Use a socket that only hits the outside rim of the new bearing when installing and tap lightly till it seats. Install seals the same way making sure they go in the same direction old ones came out. Reinstall impeller (there may be a torque setting) and pack the end of the pump shaft with grease before reinstalling the jet pump cone!
    I have never tried freezing bearings and heating up the pump but I'm definitely trying that method next time I rebuild a pump!
    Aug 2011
    Austin, Texas, USA
    Quote Originally Posted by Yabadabadoo View Post
    A 440 impeller will not come off without significant amounts of swearing, blood, and alcohol.
    Riding mostly Lake Austin
    Aug 2017
    Quote Originally Posted by Brandon577 View Post
    It sounds very similar to wheel bearing on a motorbike so it should be no prob, thanks for the input guys.
    My teacher at heavy duty mechanic college taught us the freezing bearing trick, it's awesome! heat expands metal, cold shrinks metal so you heat up the part the bearing is going into, then get the bearing you had in the freezer overnight or a couple hours and it drops right in...barely even have to tap it in...Great trick!!
    Aug 2017
    Quote Originally Posted by linkman View Post
    100% true!!! took about a week of all of the above to work!!! lol
