1995 Waverunner crazy electrics
    Dec 2017
    Timaru, New Zealand
    Hi Guys, wondering if anyone can make sense of this story. My 95 Waverunner snapped a rod so complete rebuild required. Rebore, new crank, new pistons. Whilst removing flywheel my engine rebuilder accidentally damaged the charge coil. He purchased a complete stator from the U.S and fitted this once the engine was rebuilt. Ski starts fine but doesn't rev, instead just bogs down. Replaced the Ignition coil/spark plug leads and new plugs. Forums suggested dodgy charge coil so purchased another from WMS in the States and swapped out and reassembled, no change. Tested the Temperature cutout, makes no difference if that circuit open or shorted. Finally purchased a replacement CDI from Ebay and ended up getting NO spark, no life. In midst of returning and have purchased a second hand original CDI for US$100, OEM costs US$360 and that's before converting to NZ$. The only reason for replacing the CDI is fault almost seems like it's stuck in "Limp home" mode. But why this has happened as soon as the motor was rebuilt???
    Any idea's out there, this machines are quite simple, there's nothing left to check and why the replacement brand new CDI gave no life is a mystery.
    Re: 1995 Waverunner crazy electrics
    I have had the stator (magneto) do this same thing. I think it is your aftermarket WSM parts...... Try a known good used OE stator plate assembly.
    email watcon@watcon.com
    Please visit our web sites
    May 2007
    WSM electronics suck!
    Most all aftermarket electronics suck. Check ac voltage out of the stator charge and lighting coils while trying to rev it. If you see a voltage drop instead of increase then thats the culprit.
