kawasaki 300sx pole spring
Results 1 to 9 of 9
    PWCToday Regular djsin336's Avatar
    Sep 2007
    florida
    anyone successfully use a different pole spring? the 650sx looks similar anyone get it done?
    Re: kawasaki 300sx pole spring
    No nothing else will work.
    Sep 2007
    florida
    man that sux
    it do
    Dec 2005
    QUEBEC CANADA
    i've been able to put a 750 but upside down and reverse,you will have to heat and bent (one end)that touch the pole,dont have the ski anymore and can't find any pic.hope this help,i speak french-hope what i wrote make sense
    Sep 2007
    florida
    Quote Originally Posted by justinlabonte View Post
    but the 750 spring isnt on the little bracket like the 300 one is...
    so where did you put the center of the spring theres not really a pole bolt
    Dec 2005
    QUEBEC CANADA
    the pole pin fit in the spring and i made 2 bushing to go on each side to keep it strait,you might need someone to help you hold the pole while you hammer the pin in.whish i have pic,
    PWCToday Regular goontz's Avatar
    Jun 2010
    Sykesville Maryland
    Thanks for the idea.
    I'd be interested and I'm sure some others would be as well In some pictures Of what you have done to lighten up that pole. In stock form It has to be one of the heaviest In history. I'm still having issues with mine not being able to pull me out of the water. I would love to lighten up the pole so at least some younger/lighter folk could ride and would actually be able to lift up the leadp pole!
    05 850 SXR
    05 800 SXR
    94 701 SN SJ
    93 650 SN SJ
    90 jet mate
    91 sea couch! (Under construction)
    Dec 2005
    QUEBEC CANADA
    as you can see in the pic the pole stay up-my kid were getting tired pretty quick with heavy pole,the problem is those ski are sold and dont have any pic of it.will try to find a spring and a pole to explain what it look like
