Results 1 to 6 of 6
    Jun 2017
    St. Louis
    Running Carbs Dry For The Winter
    I have Stabil in the gas and ran through the carbs now. Is it a good idea to also run the carbs dry by closing the fuel selector.
    '05 SX-R
    Thanks,
    Mike
    Pennsylvania USA
    Re: Running Carbs Dry For The Winter
    Iím pretty sure there is a drain on them. They are kinda weird because there really isnít a bowl
    Sent from my iPhone using Tapatalk Pro
    Dont run dry.
    Pennsylvania USA
    The other issue with running dry is that the fuel pump is on the carb and if that is dry for a couple months it will become brittle and crack
    Pennsylvania USA
    I would also put some seafoam in the gas and run it for 15 min
    Oct 2013
    Ohio
    There are mixed reasons both to run dry and to not run dry. Ethanol is NOT GOOD for metal specifically brass and aluminum in carbs. It is corrosive, attracts water, and leaves behind nasty deposits with it evaporates. The deposits can plug jets, etc. If your fuel has any ethanol it should be run out of your carbs.
    Premix fuel with oil in it does not age well, and should be run out of the carbs also. The oil residue left behind will keep the rubber parts soft.
    Good fuel, with no ethanol or premix will age ok over winter and can be left in. BUT, if there is a chance you may not get to run next season, run the carbs dry.
