91 superjet intake and ride plate help
    Oct 2016
    Massachusetts
    Hi everyone, I have a 91 superjet 650 that I知 planning on dropping a 62t/62t engine in. Before I mod the engine, I壇 like my ski to handle better. I was told to get a hooker 9/15 because I mostly ride on a lake, and I only really jump boat wake. I知 kind of lost on what I should do for an intake and ride plate, I was recommended a jet dynamics intake but I知 really not sure. I like to have quite a bit of bottom end but still have a ton of top end because I知 mostly racing around the lake. Thanks for dealing with my constant post guys!
    Re: 91 superjet intake and ride plate help
    Hookers are excellent impellers, but I don't think you will be happy with a 9/15. IMO they are a little low on pitch and tend to feel a little soft, even on a stock SJ.
    With our testing/builds we like the 10/16, or even a Watcon modded Large hub Solas Concord better.
    As far as scoops, and ride plates - I really like the Jet Dynamics plates. For a Scoop you may want a worx 205. The JD Scoop, or Worx 201 are also excellent, BUT more aggressive. They will scuff top speed numbers.
    I have everything available here, and would be happy to help with questions, tuning advice, etc.
    email watcon@watcon.com
    Please visit our web sites
    Oct 2016
    Massachusetts
    Sweet thanks for the advice, I was thinking around that impeller pitch and that intake.
    Oct 2016
    Massachusetts
    Thanks for the help!
    Dec 2006
    Mesa AZ
    That's very interesting. The majority of posters on the X who run hookers seem to like the 9/15 better until they get to some good mods and that's even with light aftermarket hulls. But those are mostly flat water guys too. My girls ski runs a 10/16 and it takes a second to really get going, but then again its a ported 760 so they aren't known for low end anyways.
    PWCToday.com Is My Home Away From Home afraz1er's Avatar
    Oct 2007
    BOISE
    Go with the 10/16 like John said. I run one in my 91 square with 61x, a composite d cut ride plate, and a worx 201. Its a nice combo for chasing boats. If your needing a plate John had a d cut plate for sale. I think it was a ocean pro.
    Sent from my XT1585 using Tapatalk
    - (project) 99 fixed steer super jet - 144 pump, 10/17 impeller, protec trim, R&D grate, 61x/61x 701, destroyer tubbies
    - 94 WB1, 760, superjet FP limited chamber
    - 00 24/7 carbon - solas 144 mag pump, raider trim, 9/15 impeller, jet dynamics grate, 61x/61x ported 718, FP limited chamber, KP pole, KP pole bracket
    - (project) 89 x2 - 650 pump with stuffer, 9/15 impeller, OP nozzles, 62t/61x TNT ported 753, single 46sbn, blowsion adapter, superjet FP mod chamber, ATP waterbox
    Quote Originally Posted by bored&stroked View Post
    Just an instance of you cannot always believe what you read on the internet......
    I am just saying what we have found here, with our testing. I will say, EVERY ski, build, set up is different. Aftermarket / flat water skis have different pump tunnels, etc. I just have yet to see what is the hype with a "9/15 hooker". In a regular SJ rec build the 10/16 or Large hub Solas concord hits MUCH better. 9/15 feels soft.
