Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
    May 2013
    Olalla, WA
    Re: JS 550 Crank seal question
    Its completely stock around 140psi and i run regular pump gas...
    Everything i read on here was that this was the thing to do for a typical ski.
    Anyone care to elaborate?
    JS 550 85'
    JS 550 87'
    SX 300 91'
    X2 89'
    SL 650 Triple 92'
    Feb 2002
    Vancouver, BC Canada
    Quote Originally Posted by PWCguy123 View Post
    ...Everything i read on here was that this was the thing to do for a typical ski...
    Who says that?
    I wouldn't go more than 4 or 5 degrees advance.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Apr 2006
    Oregon
    Elaborate?
    Advancing ignition timing changes the degree of crankshaft rotation at which maximum combustion chamber pressure occurs. Too much advance = excessive combustion chamber temps, detonation and seized piston. Not enough advance = A portion of the fresh fuel charge exiting the exhaust port unburned and loss of power.
    550 stock ignition timing and compression were designed by Kawasaki for the crappiest gas you would typically expect to find at some back woods marina somewhere. Running "fresh" premium pump gas with a pp 550 typically allows advanced ignition timing and/or increased compression, but that doesn't mean you should run amuck clocking the stator plate full advance!
    Home of Newmiller Machine
    Frequent Poster JustStandups's Avatar
    Sacramento
    Group K just did a great tech write up on 550 timing. Definitely agree don't advance it all the way.
    http://www.pwctoday.com/showthread.php?t=477773
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    VHP7000 #132 T1
    VHP7000 #169 T3
    VHP7000 #174 project PJS Triple 795cc
    550sx PJS all over w/ 440 fully ported
    May 2013
    Olalla, WA
    Alright, looks like i get to take it apart again. Will set back to factory settings.
    The thread i was reading was from 2008 so maybe its a bit out dated...
    JS 550 85'
    JS 550 87'
    SX 300 91'
    X2 89'
    SL 650 Triple 92'
