Results 11 to 20 of 25
    Oct 2006
    under a ton of work
    Re: JS 550 Crank seal question
    longer=better.
    Resident Guru BigDawg's Avatar
    Feb 2006
    So.Cal.
    Crank seal placement is as follows.
    Stator end - (One seal) - Spring side towards crankshaft.
    Coupler end (two seals) - Inner seal - Spring side towards crankshaft / Outer seal - Spring side faces coupler.
    Grease each seal lip with a liberal amount of quality wheel bearing grease.
    Use a thin layer of 1211 around the outer portion of each seal to seal to the case halves.
    Use a thin layer of 1211 on the case halves and bolts. Torque to specs and let set for 24 hours.
    When installing your starter, use a thin layer of 1211 again at the starter (O-ring area) to case mating surfaces.
    May 2013
    Olalla, WA
    Another question. The stator wires have two that are the same color green. How do you tell which one is which and where it goes where?
    I took pictures before hand, so i know where they go, its just there are two that are the same color!
    JS 550 85'
    JS 550 87'
    SX 300 91'
    X2 89'
    SL 650 Triple 92'
    Feb 2006
    So.Cal.
    You can install the green wires from the stator to either green wires in the box. They are interchangeable.
    Sep 2002
    gold coast
    Unless you suffer from some form of retardation do not do this
    Www.waxracingproducts.com
    May 2013
    Olalla, WA
    Quote Originally Posted by Waxhead View Post
    I must have a mild form of it, because I'm not following...
    JS 550 85'
    JS 550 87'
    SX 300 91'
    X2 89'
    SL 650 Triple 92'
    Sep 2002
    gold coast
    Quote Originally Posted by PWCguy123 View Post
    This is a picture some one posted of how they did the sealant on their cases
    May 2013
    Olalla, WA
    Got it that time...the picture quality wasn't good before, but now I can see what is going on.
    JS 550 85'
    JS 550 87'
    SX 300 91'
    X2 89'
    SL 650 Triple 92'
    May 2013
    Olalla, WA
    Thanks for the help guys. Pressure tested lower end last night and it held consistent psi without any drop after several minutes. Started up and everything is running fine, curious if I will notice a difference.
    I also advanced timing all the way counter clock wise. Saw somewhere this was best for these skis.
    JS 550 85'
    JS 550 87'
    SX 300 91'
    X2 89'
    SL 650 Triple 92'
    Apr 2006
    Oregon
    Not a good idea, especially if you are running premium pump gas with higher than stock compression.
    Unless of course you don't like your pistons and crank?
    Home of Newmiller Machine
