JS 550 Crank seal question
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    May 2013
    Olalla, WA
    85' Js 550, getting ready to put case half back together. And Yes I have the shop manual so I know what it says, looking for your opinions here. Have three of the double spring seals and 1211 to stick the two case halves together.
    Three questions:
    #1) I've got the shiny metal face of the crank seal pointing towards the pistons on the flywheel side.
    #2) I've got the shiny metal sides facing each other on the coupler side (Rubber sides facing out on both sides).
    #3) How much 1211 do you guys lay down between case halves? Just a nice thin layer on both sides then stick together? Just a thin layer on one side then stick together? Anyone know of a thread with pictures here I can reference?
    Thanks.
    JS 550 85'
    JS 550 87'
    SX 300 91'
    X2 89'
    SL 650 Triple 92'
    May 2013
    Olalla, WA
    Re: JS 550 Crank seal question
    Is anyone still alive on these forums? Don't seeing much action lately...
    JS 550 85'
    JS 550 87'
    SX 300 91'
    X2 89'
    SL 650 Triple 92'
    Aug 2002
    Seattle
    lots of the activity is moving here https://www.facebook.com/groups/621332731291152/
    Resident Guru sportsfreak29's Avatar
    Oct 2011
    Midland, Tx.
    Sounds like youre ok on the seals. I set the top half of the case, bolts down on a bench, set the crank in with new seals, and then add a thin layer of sealant to the mating surfaces of the bottom case half.
    Put the bottom half on and install the bolts to the correct torque.
    Go easy with the sealant, so you don't have a bunch of excess inside the case.
    One smooth, thin coat.
    Ski situation in limbo!
    Special thanks to Chris Newmiller, and Mitchell at M&M Marine!
    Feb 2002
    Vancouver, BC Canada
    Only put a thin layer of TB 1211 on one side.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Jan 2007
    Earth (but just visiting)
    If your smart you will use (3 ) Kawasaki 92049-3006 seals on the crank.
    May 2013
    Olalla, WA
    Thanks for the input guys!
    Quote Originally Posted by ericstratton View Post
    Yup, got em. That is what I meant by the double spring seals.
    JS 550 85'
    JS 550 87'
    SX 300 91'
    X2 89'
    SL 650 Triple 92'
    May 2013
    Olalla, WA
    So how long do you guys wait before running a pressure test?
    Want to make sure its dry before running pressure test.
    JS 550 85'
    JS 550 87'
    SX 300 91'
    X2 89'
    SL 650 Triple 92'
    Top Dog bandit88's Avatar
    Green Bay WI
    24 hours with threebond, should say on your tube of sealant
    -95 750SXI
    -90 TS650
    -91 300SX
    May 2013
    Olalla, WA
    You mean I'm supposed to read the directions?
    Thanks! Checked after 12 hours and it had set up but still a bit soft.
    JS 550 85'
    JS 550 87'
    SX 300 91'
    X2 89'
    SL 650 Triple 92'
