    Dec 2017
    INDIANA
    faulty gauge on 2006 900stx
    i bought a 2006 900 stx with a non working meter assembly. apparently the geniuses at kawasaki decided the way to go is require a different meter assembly for every jet ski made. mine requires a 25031-3747.
    this looks just like several other ones but i have to assume since there are different model numbers the assembly will be model specific. this is the first kawasaki jet ski i have owned so i am learning on the fly.
    has anyone been able to use/adapt a different model or do i need to keep looking till i find a exact match. the only one i can find so far is new at 1000.00.
    Pennsylvania USA
    Re: faulty gauge on 2006 900stx
    I do not know Kawasaki as well but I just had the same issue on my 2007 sea doo. Burnt the gauge and had to get a new one. What I found is that different part numbers r just usually different colors but same fit. That bad things is that I could not find one for under 500. New they are 700. This was for a sea doo but may apply to you
    Sent from my iPhone using Tapatalk Pro
    Feb 2015
    Southcoast ma
    Kawasaki gauges are not interchangeable will only fit the following ski,s 2001-2006 stx 900 and 2002-2005 stxr 1200
