1100 carbed motoer into a DI hull?
    Mar 2005
    Santa Barbara, Ca.
    Have a nice 1100 non-cv carbed motor and thinking of picking up a later model STX hull with a blown DI motor. Will the mounts and driveshaft line up? I have complete electrical so no issue there...
    Too much work?
    Re: 1100 carbed motoer into a DI hull?
    Should bolt right up.
    Mar 2005
    Santa Barbara, Ca.
    cool...thanks
    Top Dog
    Dec 2007
    WI
    you want a non di gas tank with reserve and no fuel pump,need to run a choke cable, and have to make your own ebox plate there are no threaded inserts on hull above drive shaft, use di exhaust.
