760 cylinder, 701 head, what gasket?
Results 1 to 10 of 10
    Nov 2011
    Wisconsin
    What head gasket am I supposed to run to make the 701 head work with 760 cylinder? Does stock work?
    1991 Superjet
    2014 Superjet
    Dec 2005
    Wisconsin
    5
    Re: 760 cylinder, 701 head, what gasket?
    Has the head been cut (squish band wise) to work with the 84mm bore?
    WHEN IN DOUBT, GAS IT!
    Nov 2011
    Wisconsin
    No because machining of the head would be against the rules, I believe.
    1991 Superjet
    2014 Superjet
    Dec 2005
    Wisconsin
    5
    I would figure people are using the OEM 760 gasket and checking squish clearance to be sure.
    Feb 2002
    Vancouver, BC Canada
    Use a 760 head gasket.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Nov 2011
    Wisconsin
    Thanks for the info guys.
    1991 Superjet
    2014 Superjet
    Dec 2006
    Mesa AZ
    Would would anyone does this to begin with?
    Dec 2005
    Wisconsin
    5
    Quote Originally Posted by bored&stroked View Post
    Racing rules.
    Nov 2011
    Wisconsin
    Translation attempt: "why would anyone do this to begin with?" ???
    Because I have to be able to run stock pipe. 64x couch head has no mounts for this.
    1991 Superjet
    2014 Superjet
    Dec 2006
    Mesa AZ
    Quote Originally Posted by Jhucke View Post
    lol good translation and explanation.
