WR650 high speed miss
Results 1 to 8 of 8
    Oct 2017
    FL
    91 650 runs great Idles good go to high speed and keeps missing and cutting out after you run for a bit it will clear up and scream New carb new plugs gapped at 28 running premix at 40:-1
    PWCToday Guru alaski's Avatar
    Apr 2015
    Alaska
    Re: WR650 high speed miss
    Quote Originally Posted by jeffinfl View Post
    Have a water seperater type fuel filter in there?
    Oct 2017
    FL
    No just inline filter
    Apr 2015
    Alaska
    Great! Might be an easy fix (except mounting sometimes). Should be using it anyway though!
    Aug 2007
    Coil wires/high tension leads are boken inside insulation. Check the plug caps also.
    Feb 2002
    Vancouver, BC Canada
    It's hitting the rev limiter. Check the impeller for debris or damage.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Feb 2002
    Chester
    It's from cavitation.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Chester is probably right on this one, those have aluminum impellers and they get chewed all to hell by this age on that ski, there is also a good possibility that either the coil wires or the plug caps have gone bad as well, I have repaired many running issues on those by installing NGK style spark plug caps in place of the crap stock ones.
