What else to do?? 750sx - Page 2
Results 11 to 20 of 28
    Jul 2015
    Huntsville AL
    Re: What else to do?? 750sx
    Yea you cant go wrong with the Jet trim. In my opinion, the heel lifters on the side tray mats are as important as sponsons, HA.
    Aug 2015
    Kalamazoo, Michigan
    I have seen this 750 in person! Super sharp, great work again John. I highly recommend Jettrim as well. I had them cover the oem pads and the thing has the ergonomics of a Cadillac or a high end sports car. So plush and comfy.
    Thanks Frank, adding Prowatercraft sponsons and Waterdawg hull extensions over the winter. That should make this ski complete.
    Jun 2009
    Cincinnati
    Improve bottom end throttle response with ignition advance plate.
    Improve rough water hook up with pump stuffer and big hub impeller.
    Improve handling with front sponsons and rear hull extensions.
    1992 750SX Limited
    1993 750SX Modified
    1996 Wave Blaster Stock
    2003 Super Jet Stock
    2005 800SX-R Stock
    2009 800SX-R Stock
    Dec 2014
    SRQ FL
    Quote Originally Posted by johnjetski View Post
    With that kind of money spent, I should just sell and get an SXR. Definitely going to get JetTrim, and maybe some front sponsons. Otherwise, it's done.
    1988 Kawasaki JS550/ Jetsport head, Westcoast pipe, PJS exhaust mani, SBN44 Westcoast velocity stack, quadrafin rideplate, westcoast intake grate, skat prop, custom paint, 4 deg bars, finger throttle
    Top Dog
    Dec 2007
    WI
    SE MI
    I have an R&D ignition advance plate if you were heading that direction.
    Frequent Poster oldguy750's Avatar
    Jun 2013
    SoCal
    Jettim for sure
    Dec 2014
    SRQ FL
    Reviving the thread... A lot has changed.
    New crank, 1mm overbore big pin cylinder, dual SBN44 on an R&D intake, Vforce Carbon v3 reeds, full motor rebuild, new everything, PJS pump nozzle, painted, dual blowsion F/A's, lightening the flywheel as soon as I can pass it off to a buddy of mine ... Excited to get her in the water. More pics and a video or 2 when she's all up and running.
    Dec 2014
    SRQ FL
    Test and tune coming up soon I hope, depending on how work goes. Dual SBN44 on R&D intake w/ carbon vforce3 reeds, 100 high and 110 low jetting... we'll see.
    Riverside, CA
    6
    How much time do you have on this current set-up? If none, how do you know
    that it isn't going to blow up on a long wot pass?
    What is your engine rpm goal?
    Your original cylinder had 178 degrees of exhaust port timing. How much does
    the new cylinder have? Big pin cylinders will have 186 or 192 degrees depending
    on your ID mark? The stock BP mark should be a 22 or 24.
    The engine rpm goal is based on the pipe and exhaust port timing.
    Is that a composite head gasket I see? Is there a step between the head gasket
    surface and the combustion chambers? Stock heads were ~.010"
    What is the current compression? Do you know how many cc's the head is?
    What impeller are you using? Exit nozzle diameter?
    PJS pump nozzle ? big fat aluminum casting with ~80, 83, or 86mm diameter.
    Bill M.
    What oil ratio do you normally use and which brand oil do you use?
    Attached Files Attached Files
