    Jun 2015
    alabama
    recover gas from 2005 VX100 deluxe
    So it's too cold to go out, but I've got two full tanks of gas. What is the best way to get the gas out? I tried to drop a siphon hose down the fill line, but there appears to be a blockage of some type that would not let me get the hose more than a foot or so.
    Thanks.
    Frequent Poster Dave in DE's Avatar
    Apr 2016
    slower lower Delaware
    Re: recover gas from 2005 VX100 deluxe
    No need to drain them just pour in some star Tron stabilizer and shake it around a bit mix, or add more fuel to fill it, and call it good. Better full actually it leaves less room for condensation to develope.
    Resident Guru kx454's Avatar
    Jan 2006
    sweet valley, PA
    Take a picture of the main harness plug and I can show you which two wires to jump to run the fuel pump.
    Oct 2013
    Ohio
    Not sure how the fuel systems are plumbed on new models. On my old ones, I disconnect the line between the tank and the filter, connect a longer line running to a can on the ground and siphon it out that way.
    I dream skis golferdude's Avatar
    Jan 2009
    Illinois
    Get you a shaker siphon and go to town
    "All out or nothin at all"
    - Jet ski owner
    '96 Kawasaki 750 SS
