Js440 crankcase studs
    PWCToday Newbie S3turbo's Avatar
    Feb 2017
    New Zealand
    Can someone help me to understand the different studs as I have a miss mash of studs
    Number 5 is 8x167mm Part number 92004-507
    Number 6 is 8x170mm Part number 92004-2084
    Number 5/18 8x167mm Part number 92004-3020 what's the difference between this and number five as they are the same length.
    The diagram doesn't allocate studs to all the threaded holes in the case so which studs go in the other holes.
    Apr 2006
    Oregon
    Re: Js440 crankcase studs
    If I remember right? the two center studs on the intake side are about 3/16" longer due to a carb brace that mounts on the top of the head and the front exhaust side stud and rear intake side studs have a shoulder on the bottom locate the cylinder on the cases. The other four studs are the shorter ones with no shoulder.
    Home of Newmiller Machine
    Feb 2017
    New Zealand
    Brillant, thankyou.
