1990 Kawasaki X-2 Compression test
    PWCToday Newbie tthede's Avatar
    May 2016
    Maquoketa
    Picked up an X-2 for cheap without hearing it run. Hull was in so good of shape I didn't care to hear it run. Going to run a compression test. What are some good numbers to look for. Also I would like to avoid buying a battery right now because it will be 7 months before ride time. Any tricks to do the test without buying a battery? Thanks guys.
    Re: 1990 Kawasaki X-2 Compression test
    Compression on a stock Kaw 650 should show 150 lbs with a quality gauge. You will need some sort of fully charged, 12v battery to install to check compression.
    Big thing is you should not see any variance between the two cyls.
    email watcon@watcon.com
    Please visit our web sites
    May 2016
    Maquoketa
    So i got 120 even in both cylinders. Would a cold engine cause it to be that low or something more? I appreciate the help!
    With them being even, I would bet it is your gauge reading low.
    May 2016
    Maquoketa
    Its a brand new gauge
    PWCToday Regular jakber's Avatar
    Jul 2016
    texas
    Did you have the choke off and had it at wot? That’s typically the best way to get accurate readings...
    ultra 150 lake travis texas
    Quote Originally Posted by tthede View Post
    Does not mean it is accurate. Is your battery fully charged?
