91 Waverunner 650 hooked up hose before starting
    Oct 2017
    FL
    I think I messed up I started the hose before starting and filled cylinders with water. How will i get the water out of the crankcase ??
    Jan 2006
    Smoky Mountains TN
    Re: 91 Waverunner 650 hooked up hose before starting
    http://www.shopsbt.com/forum/t12031/
    Default Re: SBT Ride Right Videos
    Segment 10:
    Clearing a Water Swamped 2-Stroke - Time 2:35
    Many people will unfortunately experience a water ingested engine. This segment shows you exactly how to clear it out, and what you need to do, to prevent it from becoming a very expensive repair.
    Attached Files Attached Files
    File Type: wvx 10-swamped.wvx (122 Bytes, 4163 views)
    File Type: wvx 10-Dialup_Users_Low_Res.wvx (118 Bytes, 995 views)
    Frequent Poster Dave in DE's Avatar
    Apr 2016
    slower lower Delaware
    You'll need to get it dried out asap as you'll start rusting brgs quick. Pull the plugs and crank it over to blow as much out as you can. Only crank it for 10 seconds then let it rest for a couple minutes. (Don't want to burn up starter) when no longer blowing water get it started and run on hose for about 5 min and get it warm. Then let it set and cool. Repeat running for 5 min till your sure it's burned off all water. Then fog it well for winter.
    Just realized your in Florida take it out and ride it for while instead of running on hose to dry it out. Then fog it.
    Oct 2017
    FL
    Quote Originally Posted by Dave in DE View Post
    Took it apart pulled head and manifolds cleaned and reassembled with new gaskets, New Mikuni Carb and shazamm runs great but dirt keeps getting by fuel filter and causing it to flood I think I need a better inline filter
