    Nov 2017
    indianapolis
    97 seadoo gtx wont turn over
    I need help. My ski won't turn over. Ran great a few weeks ago and just died. Couldn't get it going since. It made the 1 click sound when i pressed the button so i assumed the solenoid. Ive replaced the battery, solenoid, and starter. No luck. Fuses are good. I tried free spinning the drive shaft by hand with plugs removed on it only spins about 1/4-1/2 rotation. I'm thinking maybe busted bearing? Can anyone advise? Thanks
    Re: 97 seadoo gtx wont turn over
    Motor is toast,probably ate a rod bearing.....
    Jun 2011
    I agree with Grumpy...
    Pull the head and look inside the cylinders...
    If at first you don't succeed...
    Then you're NOT Chuck Norris!
    Sep 2008
    The flakka capitol of Florida
    Check the pump for chunks of wear ring in the impeller
    PWCToday Newbie Yscrewu2's Avatar
    Feb 2015
    Illinois
    Definitely check you pump and wear ring before ripping the motor apart
