1998 Seadoo GSXL blown fuse
Results 1 to 10 of 10
    Sep 2015
    Northern Michigan
    Had a blown fuse, 15A in the rear box. Occurred after some wave jumping. Came home and replaced fuse. Attempted to start it, it did start but was short lived. It stalled out after 10 seconds. Fuse blew again. Did some diagnostic'so found that the stator was grounded. So pulled the motor and the stator cover and found enough fine metal shavings to make me think I struck silver. Anyway along with that found this piece of metal wedged between two of the stator coils. I looked around and can't figure where it came from. Can anyone identify it.
    Sep 2015
    Northern Michigan
    Re: 1998 Seadoo GSXL blown fuse
    This is my first seadoo and I rebuilt it last year. And put it back in the hull for breakin, it going in a AM stand up this winter. Less than 10 hours on it. I was surprised at the amount of fine metal partials, is the normal.
    Resident Guru SURFnTURF's Avatar
    Sep 2004
    AUSTRALIA
    Usually the bendix teeth will break off and short the stator out.I think it is part of the inside of the bendix spring assembly.Have you tried cranking it over and see what happens with the teeth and bendix gear ? The 98s had a series of bendixs fail ,i think from memory it was from the ignition timing being advanced too far while it was cranking,under 400 revs.
    Sep 2015
    Northern Michigan
    It was cranking over, but occasionally the bendix would not engage. That is the only part that it could have come from. Thanks. Anybody have a good bendix.
    Sep 2008
    The flakka capitol of Florida
    Looks more like a random piece of metal that got stuck to the mag when you rebuilt it
    Nope its part of the starter clutch.
    Mar 2010
    NC
    I've had the same problem before. What about epoxing a maganet inside the cover to catch any debris.
    What do you think. Just trying to come up with a solution. This has happened to me more than once.
    There already is a HUGE magnet in there.....
    Sep 2015
    Northern Michigan
    Thanks for the info everyone. Definitely from the bendix. Bendix weight guide.
    Frequent Poster spinyard's Avatar
    Jul 2005
    san diego
    Quote Originally Posted by SURFnTURF View Post
    Yepp, this happened to me too, you can get the mpem reprogrammed to take some of the timing out
