Results 1 to 8 of 8
    Oct 2017
    Discovery Bay
    Grips for 7/8 Bars
    This is kind of a silly question, but I canít seem to find an answer. I just put new bars on my x2 and Iím looking for new grips. The majority of the mx grips have a rift and left with bigger hole for the left. Do people buy two pairs or will standard mx grips work?
    Aug 2007
    Re: Grips for 7/8 Bars
    If you want a style only found in mx grips, then yes you will need two sets. If you buy atv grips they will both be 7/8" size. I like the ODI grips because they lock on with clamps on the end. When they need replaced you do not have any glue or scraping involved.
    Oct 2017
    Discovery Bay
    Thank you!
    Oct 2017
    Discovery Bay
    Any other brands people have had success with?
    SE MI
    I shop bicycle stores, Mountain bikes have 7/8" bars also and many grip choices.
    Shiocton, Wisconsin
    I second the ODI lock on grips. I like the ruffian model
    because they have a slimmer feel. That's all that goes on
    everything I own now, MX, BMX, ATV, PWC. Easy install and
    easy to remove if you need to change bars, levers, ect. Well
    worth the extra money IMO.
    PWCToday Guru Jim_ii's Avatar
    Aug 2011
    Michigan
    I like the Odi Rogue model because they are slightly larger in diameter than the Ruffians for bigger hands. Odi lock ones are the best grips I’ve ever used on a PWC.
    Oct 2013
    funky town
    I run odi lock ons also.
    If you want mx grips, just buy atv grips. No twist throttle, no bigger grip. They come in the same patterns as bike grips.
    I'm only here to make you mad
