conversion ski exhaust
Results 1 to 10 of 12
    Will a stock 750sx,sxi,sxr pipe fit in a 550sx, JS hull?
    SE MI
    Re: conversion ski exhaust
    Not easily and not without modification.
    thank you.
    Chicago / Portage, MI
    Bandit got a xir factory pipe to fit in his conversion with some minor fiberglass work. But yea it's not all that straight forward. The orientation of manifold that the 750 skis use with the factory pipe rotates the headpipe too far outward and it hits the hull. I believe the xir uses the other rotation to keep the head pipe closer to the engine, and then the pipe is shaped differently to compensate.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
    charlotte,nc
    i think he was referring to the stock sx, sxi cast exhaust, not the factory pipe. i dont think ive seen anyone use a stock sx or sxi exhaust in a 550. the 650 style exhaust is the easiest way to go. it will connect to your waterbox under the nose just like the stock 550 pipe did.
    Ah yes you're probably right. I haven't seen it done before and BLRider is most likely right. By far the way to go is to use a aftermarket 650 exhaust or larger.
    2009 1100 SJ:
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
    Top Dog bandit88's Avatar
    Green Bay WI
    Yep, XIR factory pipe is kind of a red hair stepchild. Its a standard kawasaki manifold, yamaha headpipe, and the xir chamber.
    -95 750SXI
    -90 TS650
    -91 300SX
    Fastfairlane is correct. I was asking about the dime a dozen cast aluminum exhaust.
    I dream skis sportsfreak29's Avatar
    Oct 2011
    Midland, Tx.
    Factory 650 Limited.
    I'll be building a new 550sx/750 Rhaas conversion this winter and have 2 new Factory Pipes on the way. One Limited, and one Mod. After Newmiller finishes my motor, I'll be doing some testing of both chambers, and I'll post a build thread with the results.
    Ski situation in limbo!
    Special thanks to Chris Newmiller, and Mitchell at M&M Marine!
    Resident Guru madd_dips's Avatar
    Mar 2009
    Miami Beach
    One of you conversion guys must want this!
    http://www.pwctoday.com/showthread.php?t=475984
