spark plugs
Results 1 to 10 of 12
Thread: spark plugs
    charlotte,nc
    spark plugs
    question. i have a 750 out of a 94 ssxi with the green head. the when i got it the plugs were br8hs. which ive used since. most kawis ive seen all had br8es. the H plugs are shorter threaded area than the E plugs. i saw a kawi owners manual for the 94 ssxi and it said to use the E plugs. wonder why mine had the H plugs instead of the E plugs. i went back with the H plugs because i didnt want to risk the piston hitting the plug because its hanging too low in the combustion chamber. it runs fine with the H plugs but if its supposed to have the E plugs i bet it will run better.
    Re: spark plugs
    No Kawasaki ever used "H" plugs.
    charlotte,nc
    Re: spark plugs
    yeah i didnt think so. ive only ever seen the H plugs on yamahas. the threaded portion of the H plug is shorter than the E plug.
    Apr 2006
    Oregon
    Re: spark plugs
    BR8ES is what you want.
    Home of Newmiller Machine
    PWCToday Newbie mitcho4747's Avatar
    Oct 2015
    Huntsville
    Re: spark plugs
    I would definitely swap those out for some br8es. The only other model i've heard people use is the b8es (no 'r'). This is resistor versus not. And that's just with the simple set ups: if you have resistor caps, get non resistor plugs, or if you have resistor plus, get non resistor caps.
    What does it run like with the 'h' plugs in it? How much of a difference are you getting? (a shorter plug would changing the volume in the compression/squish area and proximity of the spark-but i imagine it's not much, does it REALLY make a difference?) Of course, the spark itself could have different ratings.. (power/timing wise)
    charlotte,nc
    Re: spark plugs
    going to today. it ran fine honestly. it does however use a ton of fuel. been running the shorter plugs for a while now ever since ive gotten it running. im sure after i run it with the correct plugs ill have to retune the carbs. checking the plugs they were always dark like too cold almost. might try to get out for a few today to see how it runs with the correct plugs.
    Apr 2006
    Oregon
    Re: spark plugs
    With a stock or basically stock motor you probably won't notice much of a difference in performance, if any. Depending on how much carbon has built up on the last few threads where the shorter plugs didn't reach, could get interesting when threading the longer spark plug in?
    Aug 2010
    Minnesota
    Re: spark plugs
    Wrong size-(too short) can have carbon buildup like mcn6 says. but at least he can run a thread chaser down the hole first to clean it up.
    A more serious problem is when wrong size (too long) plugs get carbon buildup on the protruding threads inside the chamber. Then you can't back the fouled plug out and have to remove the head. People worry about plugs so long they hit the piston, but even a thread or two (too long) can run the engine OK, but you can't get 'em out. Decades ago (I'm an old guy) most plugs on American made stuff were nearly all the same size. Now there are a million different plugs. Check your manual, or research a spec sheet and use the right size.
    OLDGUY sez..... "The older I get, the better I was !
    charlotte,nc
    Re: spark plugs
    the correct plugs threaded right in no problem.
    charlotte,nc
    Re: spark plugs
    dont be ridiculous, the longer plugs are going to pick up 20 hp over the shorter ones
