Riding technique on JS hulls
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Nov 2013
    St. Pete, FL
    I'd love to be able to corner like this... could you guys give me some tips?
    https://www.youtube.com/watch?v=T7syjrzc38k
    I see appropriate foot forward for each turn, I do that now so thats good. I usually press the inside rear of the rail into the water to carve the turn. He is doing this and also using the body as both a break and a support from what I can tell.
    But what are you doing with the throttle through the corner?
    Jul 2015
    Huntsville AL
    Re: Riding technique on JS hulls
    pin it to win it
    It takes full throttle to carve like that and you also need to pull the pole over toward the water. I am just learning this myself but my 650sx is a bit underpowered. I should be on my Tigersaki next season.
    Cypress, TX
    Don't want you to get "butt hurt", so the real secret is to wear neoprene bottoms ...
    Full butt drag over the rail...Do a full squat outside the inside gunwale making your hips the pivot centerpoint of the turn arc. Make the ski turn around you.
    Since the ski is underpowered and you will be butt-dragging, you will need all the throttle available from that little engine.
    Sep 2002
    gold coast
    Be Jeff jacobs
    Www.waxracingproducts.com
    charlotte,nc
    it really helps to have something to go around like a bouy or pile on etc. approach the turn at speed as you would in a car. let off the gas as you start to turn and lean and as soon as you hit the sweet spot where the rail grabs the water, give it full throttle and tuck as low as you can. the lower center of gravity the better. also helps to keep you weight towards the back to keep the pump in the water and hooked up.
    i ride goofy footed or right foot forward so making right turns where my butt is towards the water is easier for me. to turn left i do not switch my stance, i just get low and approach the turn as i would going to the right, get low, keep my weight over the pump, and pin it. having more power definitely helps. bone stock 440s and 550s are hard to carve as it is. adding a solid deep scoup open style grate definitely helps you hold an edge. if the pump comes unhooked, youre done no matter what.
    https://youtu.be/jFvK32gaL7U
    Aug 2011
    Austin, Texas, USA
    That's my problem with the JS hulls. It's definitely a challenge to keep it hooked up, especially on stock skis.
    Riding mostly Lake Austin
    charlotte,nc
    you gotta keep your weight over your back foot which should be almost at the very back of the tray. body english and being able to throw your weight around is key on the 550 hulls. once you get in chop and try to carve your 550, forget about it haha. its easy to carve in glassy water.
    Sep 2015
    Northern Michigan
    This is where the conversion skis shine. There is literally all the power you need to pull you out of the deepest corners. Just drop your weight deep in the back of the tray and pin it. Also you can side mount with a conversion JS.
    Mar 2005
    Michigan
    Get yourself Pro Watercraft Racing front sponsens!
    1997 Seadoo SPX---limited mod
    1996 Seadoo GSX--Cruiser
