    Oct 2017
    FL
    91 Waverunner 650 wont run
    Compression good, was not getting any spark so I replaced CDI and Coil started up and shut it off very quick. backed it into the water and started it it ran for 10 seconds and died, put inline spark tester in and it's getting good spark. looked in carb while cranking and gas is dripping in so I pulled the plugs and replaced them and tried again still wont start so I unplugged the stop switch and still no good any ideas ????
    PWCToday Guru alaski's Avatar
    Apr 2015
    Alaska
    Re: 91 Waverunner 650 wont run
    Think you'll need a new Mikuni needle and seat but doubtless the carb should be completely rebuilt. This is not as daunting as it sounds. Suggest you PM member RDRTTOY. He'll fix you right up mate.
    Oct 2017
    FL
    I had a kit and rebuilt the carb but It didn't come with a needle and seat. I did notice that even after you stop cranking gas continues to flow into the carb I suppose until the pressure drops. Could it be flooding ??
    I dream skis Squarenosed's Avatar
    Nov 2007
    Bonita, CA (so cal)
    If you have good compression and spark is consistent then yes it sounds like it's flooding, especially if you have constant fuel flow with nothing else going on. Do the plugs looked soaked with fuel when you remove them?
    My small fleet...[90 SN SJ ] [90 X2] [90 Jet-n-Cat ]
    Oct 2017
    FL
    Ok got my new needle and seat today after putting in new kit and needle and seat I started and adjusted high and low and it ran great and idled fine ran around the lake several times and parked it and back to the same thing. Fuel leaking into the carb after shut off, I managed to get it running but you have to keep throttle or it will load up and die. I am guessing I have a piece of dirt somewhere maybe holding needle valve open Thoughts. ??
