Results 21 to 30 of 31
Thread: New JS440 owner
    PWCToday Newbie rhyno857's Avatar
    Oct 2017
    Nova Scotia
    Re: New JS440 owner
    Appreciate all you help. I found a guy up here in Canada on kijiji that I'm talking to right now about an aluminum jug that has a 76mm bore, if i can get it for a decent price I might just re sleeve it. I saw your reply to my ad bionic racing, are they in good condition? i would definitely be interested if you didn't mind shipping to Canada. In your opinion is it worth it to re sleeve a jug or find a better bore? I plan on tearing the whole engine apart and fix whatever needs to be done so I appreciate the knowledge. I didn't start it personally but was told that it ran great but bogged when you gave it gas.
    I dream skis Bionic racing's Avatar
    Idaho/California
    Re: New JS440 owner
    On a resleeve less expensive to get a good cast iron cylinder , the ones I have are cherry, check on his also but might be too much to do , have shipped to Canada before and played the declaration of values game for Canadians , eh ?
    Oct 2017
    Nova Scotia
    Re: New JS440 owner
    He said $275 shipped (seems steep) for the 76mm bore aluminum. What would you be looking for for one of your cast irons?
    Idaho/California
    Re: New JS440 owner
    Mine will probably be std bore , with head 200$ U.S. plus ship, probably 250-260 range
    Oct 2017
    Nova Scotia
    Re: New JS440 owner
    Well since you have given me so much information/help I would rather give my money to you. Let me know when you get back to Cali and we'll get a deal going.
    Re: New JS440 owner
    Quote Originally Posted by rhyno857 View Post
    This is how it should be, good job dude.
    Idaho/California
    Re: New JS440 owner
    Also strip bottom end and check crank , if front main bearing is bad I also have those in stock and can ship in same box
    Oct 2017
    Nova Scotia
    Re: New JS440 owner
    It might be another couple weeks before I have time to pull out the engine and really start stripping it down. Lot on the go this week and next week I'm heading to Montreal for a week, plan on doing it when I get back from that trip. Definitely will check it out. Waiting for my Clymer manual to get in so I can pull the crank and throw it on some v blocks with some dial indicators to see if it's in spec. Are there any other things i should check while I have the crank out? Anything else that's known to go?
  9. #29
    Aug 2011
    Austin, Texas, USA
    Re: New JS440 owner
    Since you will have it apart replace the crankshaft end seals with Kawasaki OEM ones.
    Riding mostly Lake Austin
  10. #30
    Idaho/California
    Re: New JS440 owner
    Your manual will give you stator specs, ohm it out since you have to assume it ran before you purchased from the same guy that said it was a 440 , affirmative on above post also
