2008 RXP-X 255 DESS Post issue + compatibility questions
    PWCToday Regular I8A4RE's Avatar
    Gilbert
    2008 rxp-x 255
    my 4 WIRE dess post occasionally will not acknowledge the key when placed on it. i wack it a few times w a screwdriver handle and it starts to work. i figure one of the reeds inside is sticking.
    MY QUESTION IS..... will other dess posts w 4 wires work since the security microchip is in the key and not the post?
    my stock post part number is 278002351 but cost $95+ on ebay
    similar 4 wire posts (part # 278002055 287002774) are only $36 on ebay
    is there any difference internally between them?
    They all have the same color coded 4 wires. has anyone replaced their post w a different part # w no issues?
    Thanks.
    Speed never killed anyone. Its the sudden stop that gets ya!
    88 440 new 550 reed engine, PJS case, 44mm Intake, LS Exh maifold, westcoast pipe, 46 mikuni w primer, wiseco 76.5mm pistions, K&N filter, bad bones reeds, Jetlyne ss imp, 440 pump.
    89 650sx fully rebuilt engine, west coast exh, Keihin 42mm w primer, milled +o-ringed head, scat trak imp, ride plate, K&N filter, Removed oil pump, dry cell battery, new paint+pads
    Aug 2008
    Indianapolis
    Re: 2008 RXP-X 255 DESS Post issue + compatibility questions
    All the 4 wire DESS posts are functionally equivalent....
    May 2009
    the 'ville, kentucky
    clean it with a pencil eraser
