Best pipe for sxi pro? - Page 2
Results 11 to 16 of 16
    PWCToday Regular newtondeegan's Avatar
    Aug 2017
    Lake Havasu City, AZ
    Re: Best pipe for sxi pro?
    restosud, on your race pros you used the pro fp dry pipe?
    I'd personally recommend the Nynja / TNT Superstock or Speedwerx. As far as wet pipes go for racing I'd definitely recommend the Nynja / TNT over the FP limited pipe.
    I thought TNT doesn't make pipes for the sxi pro? I talked with Tynan and that's what I thought he told me. He was going to be my first choice.
    What is Nynja, and where do I find them?
    Top Dog
    Oct 2006
    under a ton of work
    tnt will not fit on kawi motor without heavy hammering and there is no manifold for a lay down style plus the gas tank is in the way.
    yes,i ran fp dry and regret selling this boat and pipe.
    i wouldn't put a nynja on my lawnmower!
    Chicago / Portage, MI
    It is my understanding the Nynja is a copy of one of the better TNT pipes, the Superstock one. Yes, it does fit. Mine shown in the pictures had no chamber dents / modifications at all.
    Not sure what your issue is with the Nynja restosud. They are sought after pipes which have a broader power band than the FP limited pipes. Their performance benefits over the limited are pretty well documented online here. Granted they are copies of the TNT pipe, but they were copies made because at the time, Tim wasn't making more. As far as craftsmanship and performance goes though, you can't fault them. And I must say, this is just a personal preference, I think the TNT / Nynja looks amazing compared to the somewhat blah looking limited pipes. And also I have never used a fp sxi pro dry pipe, but from what I have heard about them, I have no desire to use one of those either. So to each his own.
    We ran back to back ported 800 pros with the fp limited and Nynja pipes. Details are in my build thread, there's only so many times I can write this stuff out.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
    Dec 2014
    SRQ FL
    I have a full factory pipe wetpipe setup for sale for $600 shipped
    1992 Kawasaki SP 750sx - Big pin cyl, 1 mil overbore, Triton Engineering head, V-Force Carbon v3 reeds, Coffman Signature series pipe and silencer / WB bypass, dual SBN44 on R&D dual singles, Blowsion F/A, AC Racing -2 alum pole, Jetworks bars, full Jettrim, OP rideplate, Westcoast scoop grate, OP steer nozzle, blueprinted aluminum pump nozzle
    Aug 2017
    Quote Originally Posted by StuRat View Post
    PM me w/ some pictures.
    Dec 2014
    SRQ FL
