Results 1 to 10 of 11
Thread: 2 Stroke Oils
    Oct 2017
    New Zealand
    2 Stroke Oils
    Sorry for the newbie questions.......cant see any definitive quick answer in the search function without days of going through tons of irrelevant pages
    What oils are people using for pre-mixing?
    Synthetic or mineral type?
    Any particular brand or grade been better than others?
    Cypress, TX
    Re: 2 Stroke Oils
    Synthetic is best.
    What quality/grade of oil depends on the Manufacturer's recommendations, for a completely stock pwc.
    Guys will freak when I say this, but I just use $12/gallon Walmart SuperTech TCW-3 oil on all my Stock and Limited Pump Gas Jetskis. Most rev between 6800 and 7300 rpms, Have one that revs at 7600 rpms going strong for 3 years now.
    Better to list your PWC set-up and peak rpms: compression, carb sizes, pipe, impeller; then recommendations can be made for your PWC.
    It is critical for the engines to be air-tight and for the carburetors to be tuned right first. Thereafter, oil quality requirements are a direct function of piston speed, thus engine rpm.
    Re: 2 Stroke Oils
    Walmart supertech FTW !!!
    Aug 2010
    Australia
    Re: 2 Stroke Oils
    cheap stuff with tcw-3 rating, or you could use the flash stuff for $40 a jug just to prove you have lots of money and have brand name oil in your ski .
    modded X2 650
    Originally Posted by hyosung
    Re: 2 Stroke Oils
    I've run the Supertech and Quicksilver outboard stuff for years with no issues.
    Thinks everythng sux =) Top Dog vomitspot's Avatar
    Mar 2005
    lost
    Re: 2 Stroke Oils
    i use amsoil in my ski
    its full synthetic
    and klotz in my leaf blower
    nina hagen daz
    Top Dog aggrovated's Avatar
    Frozen Tundra, MN
    Re: 2 Stroke Oils
    Yamalube @60:1 ratio. I use a sharpie on my ratio-rite. I like my purple gas in my white jugs. Easy to see how much I have left.
    Jan 2006
    Smoky Mountains TN
    Re: 2 Stroke Oils
    Been using Walmart supertech but not sure if it will cause any damage over the long term as I've only been using it for 18 years or so?
    Oct 2017
    New Zealand
    Re: 2 Stroke Oils
    Been given a full bottle of this to use...
    http://www.maximausa.com/product/marine-pro/
    Nov 2004
    Homer, NY
    Re: 2 Stroke Oils
    Quote Originally Posted by don37725 View Post
    Don, is that 18 years on the same, unmolested engine? I have 17 yrs on my 2000 SLX, never opened the engine once. I'm not running Supertech, however.
    '03 Octane, Watcon 2318 CDI
