    PWCToday Guru Udjenl's Avatar
    Aug 2013
    The netherlands
    jetnetic flywheel gearring removal.
    Does someone know how to remove the Gearring from a jetnetic flywheel?
    i think the follow whil work..
    Heat up to 200 degrees in a offen than get it out.
    then let water only cool the alu so it shrinks..
    i think the wheel have to fall of automatic...
    can someone confirm it?
    work hard and play hard
    or let someone else work hard and still play hard.
    but enjoy life every freak'n day
    Aug 2013
    The netherlands
    Re: jetnetic flywheel gearring removal.
    Got it of..
    is there a place to get a new ring?
    Aug 2013
    The netherlands
    looking what gearring whil fit. insidediameter is 12.8cm anyone that have a flywheel from a 750 or superjet laying around to check diameter of it?
    SE MI
    If you heat the ring gear up enough to spin it around, spin it 90. The starter engagement location will be near new.
    Aug 2013
    The netherlands
    found out that a 650sx gearring is the same diameter ��
    Jul 2012
    milwaukee
    do what BLRider said , we did on cars with manual trans all the time
    Aug 2013
    The netherlands
    have looked at it bit has to much damage to trust it.
