701 swap impeller
    PWCToday Regular Ltr171's Avatar
    Jun 2013
    North Carolina
    701 swap impeller
    What impellers are you guys running with the 701 on a stock pump?
    Top Dog TMali's Avatar
    Mar 2011
    Brooklyn Center, MN
    Re: 701 swap impeller
    Id go with a 9/15 or 10/16 hooker
    Jun 2011
    Norcal
    Assuming in a x2- I second the low pitch hookers.
    I'M running a 9/16 skat tho
    - John Kenneth Galbraith
    Aug 2008
    CT
    how much does the rider weigh and what are you using the ski for?
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    Jun 2013
    North Carolina
    Quote Originally Posted by Twinturbostang View Post
    I only weigh 125 and I just ride surf and boat wakes at the lake.
    Aug 2008
    CT
    9/15 big hub swirl then will give you the snap
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    Jun 2013
    North Carolina
    Sweet thats what I use in my yamahas.
