96 XP WOT only 6350 RPM's - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    Re: 96 XP WOT only 6350 RPM's
    There is a spring at both sides of bellows
    PWCToday Regular Case1's Avatar
    May 2017
    Gun Barrel City, TX
    Hmmm...All that came out was that big spring in the first pic
    May 2017
    Gun Barrel City, TX
    OK, so I have the parts to fix it. Question, How far do I tighten the screw going through the middle, lightly seated and then make sure the red cap on top of the cover is 3 turns out?
    PA
    Been a while since I had mine apart, so not sure if others would agree to put a drop of blue Loctite on the stem thread.
    May 2017
    Gun Barrel City, TX
    Quote Originally Posted by rdjeep View Post
    I believe you are correct on that tip rdjeep. I looked in the manual and it showed to put some on the stem. Also, the manual said to turn red cap all the way in then out 3 turns for factory setting.
    May 2017
    Gun Barrel City, TX
    Dang! So I get the newer regulator on it today and itís Leaking more than the old one.
    Thank God I am not a newbie anymore 😂
    I have never seen one work properly once the inner part is pulled out.
    May 2017
    Gun Barrel City, TX
    OK, so look for a newer one that has not been taken apart and is still in good shape or a brand-new one?
