Thread: Impeller Help
    Oct 2017
    Discovery Bay
    Impeller Help
    Iím trying to decide on an impeller for my 93í x2. The two I have been bouncing back and forth on are a Skat trak 55 and a Solas 13/18. The ski is completely stock at the moment, but in due time will have head, pipe and carb. Iím struggling to find a definitive answer on which is the best choice. The ski will be used in the CA Delta and lakes and Iím looking for a happy medium of bottom end and top end performance.
    Resident Guru still standin's Avatar
    Jul 2009
    michigan, KZOO
    Re: Impeller Help
    Skat 9/17 Standard was great on my 650 X2 with modded stock pipe, 44 SBN Carb
    -Bulldog Freestyle 550/750 - http://www.pwctoday.com/showthread.php?t=457962
    -92 550sx/650 conversion
    -94 750sx modded
    -86 X2 - Twin carb 750 swap
    Top Dog bandit88's Avatar
    Green Bay WI
    Re: Impeller Help
    Are you planning on buying one new? If so I would look at a Skat 8/16 or 9/17 depending on your mods. If you already have the two you mentioned, I would probably go with the Skat or have it re pitched to a variable pitch
    -95 750SXI
    -86 440 with PJS800 conversion
    -90 TS650
    Oct 2017
    Discovery Bay
    Re: Impeller Help
    I am looking to purchase currently. Those are the two that I have found locally. I will keep looking for a 9/17
    Green Bay WI
    Re: Impeller Help
    What mods do you have, in most cases I have preferred the 8/16 over a 9/17 on 650s. I would recommend ordering from impros. They make sure the pitch and balance is in spec before shipping it to you.
    -95 750SXI
    -90 TS650
    Oct 2017
    Discovery Bay
    Re: Impeller Help
    Currently bone stock. I will be looking to go with 44sbn, pipe and waterbox in the future. Figured I would start with the impeller then go from there.
    Green Bay WI
    Re: Impeller Help
    Get a 8/16. Will be good for stock and those mods. I would not run a 9/17 on a 650 until it has some porting.
    -95 750SXI
    -90 TS650
