    PWCToday.com Is My Home Away From Home Camasaki's Avatar
    Mar 2013
    Palm springs ca
    Kawasaki Js550 vs 650sx steering cable.
    Will a 550 steering cable work for a 650?
    I've found that the Js length is 3 inches longer which should be fine, but the throw is 3/8 shorter.
    Is their enough thread to gain that difference?
    You can't drink all day, if you don't start in the morning.
    Top Dog bandit88's Avatar
    Green Bay WI
    Re: Kawasaki Js550 vs 650sx steering cable.
    Probably not, im sure Kawi would have used the same cable if they could have. You might be able to get away with using the JS cable and a 1" extension.
    -95 750SXI
    -86 440 with PJS800 conversion
    -90 TS650
    Mar 2013
    Palm springs ca
    Well I'm going to try it anyways considering I've got a few laying around.
    I'll update with the answer when I get around to doing it.
    Mar 2007
    Is Everything!
    Wouldnt you also want to use a 650 steeing plate and pivot bolt as well to maximize performance. However, is there a difference between the cable aside from throw? Ie mounting placement.
    Mar 2013
    Palm springs ca
    Not sure on washer placement location or what not.
    All 650 parts on 650, just attempting to be cheap and use a 550 cable.
    I was hoping to hear, "o yea not a problem ive done it pleny of times!"
    I'll update once I try fitment. Maybe I can be that guy one day.
