Results 11 to 20 of 31
Thread: sx750 issues
    Sep 2015
    Northern Michigan
    Re: sx750 issues
    With anything that has been setting for a while, and of age, I would at a minimum replace the fuel lines, rebuild the carbs, and replace the crank seals. I also highly recommend removing the oil pump on those and switch to mix.
    I second what Bandit is saying. Those cranks seals need to be replaced if it sat for years.
    Chicago / Portage, MI
    Re: sx750 issues
    And I third it. Replace crank seals and ditch the oil injection for sure.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
    Oct 2017
    New Zealand
    Re: sx750 issues
    Pulled the motor out of the ski with issues.
    Removed the crankcase drain valve. Heaps of 2S oil came out, I'd say nearly 250ml.
    Drilled the holes in the casing out to size, tapped them, and fitted 1/8" npt bungs.
    Also removed the oil pump on the front of the motor and fitted a blanking plate there.
    Just need to look at the fueling side of things as it wasn't getting any fuel through.
    Oct 2017
    New Zealand
    Re: sx750 issues
    No wonder it had a fuel issue
    There was no way anything was getting through this crap.....
    Oct 2017
    New Zealand
    Re: sx750 issues
    Carb is a write off. Going to get a good secondhand carb. Carb kit alone is $140, then there's the vapour blasting as I don't think a good soaking will do anything, and the broken screws as well.
    I can get a used carb off a good runner for $100.
    Makes more sense to bin it and get another
    Aug 2017
    Vancouver Island, Canada
    Re: sx750 issues
    Quote Originally Posted by Cambo View Post
    either way you will still need to buy a rebuilt kit. They are only like $20 for aftermarket or $50 for oem(which I recommend), then needles and seat if needed which is most likely $20. I'd put it in a bucket full of diesel for a couple of days, then have a good look at it, full disassemble, clean it, check all passages, and rebuild...You'd be surprised how those things can come back to life... I've had ones look like that, the side you posted pic of usually gets the worst of it
    Oct 2017
    New Zealand
    Re: sx750 issues
    I wish we had those US prices here. In NZ the aftermarket kits are $140. OEM are moonbeams and not even worth considering.
    This pos has too any broken screws plus all the corrosion anyway. Really can't see the point in spending too much on it plus my time.
    Aug 2017
    Re: sx750 issues
    Don't you have Ebay there? I'm in Canada and I order parts from the USA on eBay... Also lots of guys on here selling quality new part that I'm sure would send them to you. I've sold parts all over the world for the same price with extra cost for shipping
    Oct 2017
    New Zealand
    Re: sx750 issues
    Quote Originally Posted by Yabadabadoo View Post
    I will check that out, but I normally like to support local business.
    Aug 2017
    Re: sx750 issues
    Ya me too, but not if they're ripping me off.
