    Oct 2017
    New Zealand
    Newb With Twin SX750's
    Gidday fellas
    My Brother In Law gave my kids his old pole skis that have been sitting around for nearly 10 years.
    I've got 1 going pretty easily, but the other may take a bit more work.
    Joined for more tips tricks and info really.
    Only 2S stuff I've had anything to do with is MX bikes and outboards.
    Oct 2017
    New Zealand
    Re: Newb With Twin SX750's
    The 1 I haven't got going yet is pumping out oil from cylinder 2 when the plugs are out.
    Going to have to remove the intake now and check carby and reeds.
    Also been recommended to delete both the oil pump and crankcase ventilation valve as they're prone to failing and causing engine failures.
    Seeing as they've been sitting for ages, its more preventative maintenance than modding.
    Dec 2014
    SRQ FL
    Quote Originally Posted by Cambo View Post
    crankcase blockoffs are a must. Same with oil pumps. Run 40:1.
    Nice pickup. How much?
    1992 Kawasaki SP 750sx - Big pin cyl, 1 mil overbore, Triton Engineering head, V-Force Carbon v3 reeds, Coffman Signature series pipe and silencer / WB bypass, dual SBN44 on R&D dual singles, Blowsion F/A, AC Racing -2 alum pole, Jetworks bars, full Jettrim, OP rideplate, Westcoast scoop grate, OP steer nozzle, blueprinted aluminum pump nozzle
    SE MI
    Gidday fellas
    Quote Originally Posted by StuRat View Post
    Looks like they were free.
    Oct 2017
    New Zealand
    Yeah free. BIL gave them to my kids (17yr and 13yr)
    Just have to get them running and rebuild the trailer
