    Nov 2002
    CA
    GS GSX custom storage under the seat
    Ive been enjoying my GSX Limited for the past year, but one huge gripe i have about the ski is its lack of accessible storage compartment while sitting on the ski. Every ski ive owned has had at least a little compartment in front of the rider. I had an idea to put a compartment under the seat in the hose vent baffle by eliminating the 5 inch round tube, and cutting out a rectangular hole in the flat section and integrate a tray in there. But my concern is airflow... By doing this would i be choking off the intake air from the engine? If so, maybe ill use a screen material so that air can still pass through? And/or drill several holes on the flat section? Any thoughts ideas suggestions for getting some kind of accessible compartment.
    Love the ski, hate having no compartment!!
    Mar 2010
    NC
    Re: GS GSX custom storage under the seat
    I don't think that would upset air flow. I think it's a good idea.
    Jan 2006
    Smoky Mountains TN
    The in and out air vents are as much, if not more so, about venting possible gas fumes - That 5 inch round tube reaches down toward the bottom of the hull which is where gas fumes would settle - Replacing it with netting and drilling holes etc will not vent the bottom of the hull as the original design is meant to do.
    The odds of you having a gas leak and explosion are most likely very small but, if it happens, the negative results could be very serious - do you feel lucky?
    Maybe a handlebar bag? - Here is one example but there are many styles and options to choose from.
    https://www.amazon.com/dp/B074H6Z4NK?psc=1
    Nov 2002
    CA
    My thought of that tubing was for noise suppression and provide air for the engine. The parts manual calls it "noise cancellation" foam
    Jan 2006
    Grandville MI
    The front hood opens and has storage under it. If you want to get creative and make more room in it, you can remove the tubes and install the fire exstiguisher in the engine compartment like the RX based platforms.
    Nov 2002
    CA
    "lack of accessible storage compartment while sitting on the ski."
    Jan 2006
    Grandville MI
    you won't be sitting on the seat if you have it off to play with the tube under it. good luck with your design.
