Results 1 to 8 of 8
    PWCToday Guru Jim_ii's Avatar
    Aug 2011
    Michigan
    SXi Pro no low end response
    Hello all,
    We have two SXi Pros ('98 and '99) with identical setups. New top ends, factory mod pipes, milled heads and hooker props.
    Recently the '98 lost most of it's low end "punch". I know the big pin motors aren't good for low end anyway but compared to the '99 it's really noticeable.
    Started about 4 rides ago. Prior to that both skis were virtually identical in power delivery.
    I've checked compression on the '98 and it's right where it was on both cylinders after the new top end. I swapped the electrical boxes between the 2 skis and that didn't make a difference.
    I'm thinking maybe I broke a reed?
    Anyone ever experienced this on a 750? If yes, what did you find to be the problem?
    Thanks for any ideas.
    Aug 2011
    Michigan
    Re: SXi Pro no low end response
    Any ideas?
    Top Dog hooka-2's Avatar
    Nov 2005
    sebring florida
    check down the throat of the carbs with the ski idling for fuel dripping out of the bomb site. If the needle and seat is worn it will drip and cause the engine to load up at low rpm
    90 X2 (750), 92 X2 (750), 93 X2 (750),93 X2 (750), 99 Ultra 150(sold) 1995 Waveblaster 1
    Aug 2011
    Michigan
    Thanks for that tip hooka-2 I will look later this week.
    Also forgot to mention that the one with no bottom end power seems to smoke a whole lot more than the other ski. Both are running 50:1 premix.
    PWCToday Guru kotarbi's Avatar
    Jan 2003
    san antonio tx
    Start it with the hood off and look for any exhaust leaks
    07 Hydro Triple!!
    06, 07 SXR's
    93sx-Pro
    85,87 wetbikes
    Aug 2011
    Michigan
    Quote Originally Posted by kotarbi View Post
    Yep tried that. No apparent exhaust leaks.
    Top Dog bandit88's Avatar
    Green Bay WI
    I would inspect the carbs and the reeds.
    -95 750SXI
    -90 TS650
    -91 300SX
    Aug 2011
    Michigan
    Carb inspection was a good idea. The butterfly on the rear carb wasn’t moving. Set screws on the linkage between the carbs had come loose. Easy fix!
