Results 1 to 10 of 14
    PWCToday Regular netdr's Avatar
    Maryland
    Superjet won't stop cranking
    Rode about a week ago and this weekend I was getting ready to winterize my ski
    When I tried starting, the engine cranked and started, but being cold it stalled when I tried to start it again, after pulsing the starter, it wouldn't stop cranking to start and the battery just got weaker and weaker until it just was getting a crank every second or so - I was not pushing the starter. The only way to stop the crank was to disconnect the battery. When reconnecting, it would start again...
    Starter? Solenoid?
    Just got this primo 2001 701 this summer to add to my collection. Help?!
    Maryland
    Re: Superjet won't stop cranking
    To be clear...it started cranking again, not firing up. I put the battery on charger to get ready to troubleshoot ideas...thanks.
    SE CT
    Sounds like that.Only other thing it gould be is start button.
    R.I.P. Super Sic
    Jun 2017
    Connecticut
    It sounds like your start/stop switch. The contacts in your start button are sticking. This may be cause by a weak spring in the button, or corroded contacts.
    I had the same issue. The spring was completely dissolved into a rusty powder. I used a spring from a click pen to fix it
    Jun 2017
    Connecticut
    Aug 2011
    Austin, Texas, USA
    Start switch or solenoid is the problem. It's definitely not the starter motor.
    Riding mostly Lake Austin
    Maryland
    Quote Originally Posted by dorny119 View Post
    But, if I removed the lanyard and it was still cranking? That should have cut the circuit for the start switch even if it was stuck, correct?
    Maryland
    Since something is stuck closed circuit, I will check for continuity tonight in the switch and the relay...that should give me an idea. Looking up relay prices local...
    Aug 2011
    Austin, Texas, USA
    Quote Originally Posted by netdr View Post
    Many skis have the start and stop circuits/buttons very separated. It's possible to press both buttons at the same time resulting in cranking the engine over plus inhibiting the spark.
    I dream skis JC-SuperJet's Avatar
    Cypress, TX
    While you wait for your new Relay, why don't you open up the Start/Stop Switch, clean, inspect and repair if needed. Simple easy preventive maintenance step and narrows down the short list of possible causes.
    Seee http://www.pwctoday.com/showthread.php?t=397400&page=2 Good photos...
    Search function is very useful...
