First start 93 vxr 650
    PWCToday Guru alaski's Avatar
    Apr 2015
    Alaska
    Exclamation First start 93 vxr 650
    Hi. So I'm getting close to running this thing after complete refurb. and have hooked the main water inlet to the exhaust manifold at the point where there is a smaller line going to the head as instructed here ad nauseum lol (and teed off for the water hose). Starts up great and sounds good, turn on the water hose and see water streaming out under the manifold on the PORT SIDE (other side from carb.). Wtf!??
    Here's a pic of where it's coming from. Despite my profile I'm still only a newbie so looking for guidance on why, what is this outlet and why is it not mentioned in the Yam shop manual.
    Also I don't remember even seeing this outlet during reassembly when the engine was out!
    (that's the rear port side engine mount in the foreground)
    Thanks so much!
    Re: First start 93 vxr 650
    That is the fitting for the hose that comes in feeding water from your jet pump.
    Line in from pump to that fitting.
    You will have another fitting on the lower pipe manifold that a hose goes up to the fitting on the rear side of your head.
    email watcon@watcon.com
    Please visit our web sites
    Apr 2015
    Alaska
    Thanks awfully John.
    I'm wondering now what happens to the vacant input next to the one going to the head after I remove it? Maybe it should be for the garden hose? As mentioned, none of this is clarified in the shop manual so please forgive me for labouring the point.
    I do have the water input line from pump teed off to the garden hose fitting if that helps.
    I dream skis Squarenosed's Avatar
    Nov 2007
    Bonita, CA (so cal)
    Main feed in from pump goes to the fitting you have pictured. Normally a flush kit is installed where the red arrow is pointing. Hope this helps.
    My small fleet...[90 SN SJ ] [90 X2] [90 Jet-n-Cat ]
