2007 ultra 250x new engine ?
Results 1 to 10 of 12
    Aug 2017
    North Dakota
    So I am picking up this 2007 ultra 250x with blown motor for $500. Hole in crank case, by top half at rear piston ...rear piston damage as well, cylinder wall has gash in it ....no head damage.
    Some fiberglass damage on left side not bad.
    Where is a good place that rebuilds these or best options for me. Everything is there torn just torn apart.
    Re: 2007 ultra 250x new engine ?
    May sound like a good deal till you start adding up stuff that does go bad.....intercooler-$2054.00 & supercharger at $2004.00.....I would say pass,not a good deal.
    Top Dog aggrovated's Avatar
    Frozen Tundra, MN
    no one will want to rebuild this ski, too much trouble... not worth it.
    Build it yourself.. expect to pay at least $4000 rebuilding it. I know I did it. Also, That's a bad year for a 250x.. lots of inherent problems... check out greenhulk.net.. a 250x hangout
    Aug 2017
    North Dakota
    So sbt I believe rebuilds for $2000 something to look into doing
    Aug 2007
    Yes, for the short block. They will charge you retail for the cases and cylinder damage on top of that. You will be into it more than the ski is likely worth.
    Aug 2017
    Southern NY
    The costs add up fast. Just went thru this on a non-boosted engine replacement. Couldn't believe what just the bearings went for. Just doesn't seem right.
    Built a 502 BBC for my Chaparral SX boat for not much more than the little 4 bangers cost.
    Aug 2017
    North Dakota
    How much just for engine .. then upgrade shaft to 2011
    Quote Originally Posted by aggrovated View Post
    Expect at least this much if doing it yourself. I did one earlier this year. Figure in the KP Performance pump upgrade kit too.
    Aug 2017
    North Dakota
    So it would be better to buy it for $500 and part it out probably?
    Thats if anything is still good....
