WaveBlaster II 1200 Conversion Build - Page 3
Results 21 to 30 of 46
    Feb 2004
    Phoenix, AZ
    Re: WaveBlaster II 1200 Conversion Build
    Quote Originally Posted by 2strokesmoke View Post
    You should be able to rotate the exhaust outlet to fit flush and the tubing should be parallel to the hull. The exhaust outlet was designed for the blaster hull with the taper in mind.
    I can rotate the outlet to make it parallel with the hull but the transom on a B2 is convex, not flat like a B1
    1996 XP All the usual mods
    http://www.pwctoday.com/showthread.p...17#post4380117
    1996 WaveBlaster II 1200 conversion in progress
    http://www.pwctoday.com/showthread.php?t=477231
    Yea ,I remember rotating the outlet till it was flush as possible to transom. My screw holes are in the same pattern orientation as yours, maybe I just got lucky. Did some GPS testing last weekend on the B2 1200. Got 53 mph at 6350 rpm (needs to be 6800-7000). 15/20 small hub swirl prop with Riva scoop grate and Ocean Pro ride plate. Still needs some dialing in, but it is MUCH more fun than with the 760.
    Feb 2004
    Phoenix, AZ
    How did you mount your waterbox?
    Just put a piece of turf down. The hoses hold it in place pretty tight.
    Feb 2004
    Phoenix, AZ
    The bed plates are almost complete, just have to line up the engine and drill the holes for the motor mounts.
    Oct 2017
    Florida
    2
    Don't think I replied correctly lol. But so my mechanic is helping me take the outlet and inlet off gp1200 waterbox and welding it to my WB2 TDR-P box so I won't have to get another box. Also, what midshaft is best, 701 or gp760 (heard 701 recommended). For prop was thinking about 13/19/ but talked to Dave from extreme throttle and he said his 1100 triple B2 had an 11/19. Then reading here I see different recommendations so what worked for you guys?
    Dave knows his stuff. He helped us through out build. Picked up the 14/20 for cheap, but is a little too much pitch for the b2 hull. Gp 760 mid shaft is the best. Sets the engine back to the furthest
    Oct 2017
    Florida
    2
    Perfect, thanks!!! I'll be sure to follow up when my build is complete!
  9. #29
    Feb 2004
    Phoenix, AZ
    X2 on the GP760 midshaft.
    Picture of the mock up motor installed with the GP760 midshaft and 98 XL1200 exhaust hose.
    If you can find one the 98 XL1200 stinger to water box exhaust hose fits way better than a Raider 1100 or GP1200 hose becuase the bend in the XL hose lines up better with the hole in the bulkhead.
  10. #30
    Feb 2004
    Phoenix, AZ
    I picked up a magnum pump with two impellers and a Riva CDI recentely so I figured I would share some jet ski porn.
