WaveBlaster II 1200 Conversion Build - Page 2
Results 11 to 20 of 35
    Feb 2004
    Phoenix, AZ
    Re: WaveBlaster II 1200 Conversion Build
    I'm planning to use the XL1200 water box but I will need to cut a large hole in the bulkhead to get it in. It wont fit through the opening for the battery box. I was thinking in would cut the hole the same size as the hole on a GP1200 and use the GP1200 acordian seal to cover the hole.
    The extreem throttle waterbox looks smaller, were you able to fit it in through the battery box opening?
    1996 XP All the usual mods
    http://www.pwctoday.com/showthread.p...17#post4380117
    1996 WaveBlaster II 1200 conversion in progress
    http://www.pwctoday.com/showthread.php?t=477231
    Sep 2008
    City of Blasters
    The Waveraider 1100 #1 waterbox has a smaller diameter. That is what we use on B1 Yamaha triples. Fits right in the B1 battery box.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Traci Cottle Photography
    Greg Barnhart Photography
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    Sep 2008
    City of Blasters
    Quote Originally Posted by a1965gt View Post
    Just double checked the I have a YD-SC-X (13-16) prop, probably on the small side. I'll start looking for somthing bigger.
    I really wish Solas made an affordable 12V big hub pump.
    That prop should work pretty good. I have a solas 12-18 in a B1 only pulling about 6500. Stock motor.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    May 2011
    miami
    The extreeme throttle box does fit right in without any cutting.
    Feb 2004
    Phoenix, AZ
    I think I'll try a Raider 1100 waterbox. Looks like it small enough to fit in through the battery box opening.
    I would also like to relocate the waterbox mounts from the right side of the hull to the left. Anyone know a good way to remove the factory green glue from the hull?
    Feb 2004
    Phoenix, AZ
    The Raider 1100 water box and Extreem Throttle rear exhaust showed up this week. The 1100 water box is the same diameter and just a little longer, the XL1200 box is in the photo for reference. The 1100 box fits in the hull with no problem. Just need to figure out how to remove the water box mounts without damaging them so I can reuse them on the left side.
    The rear exhaust is nice but has some manufacturing marks on the ring that I tried to polish out but you can still see them.
    Feb 2004
    Phoenix, AZ
    I had the day off today started working on my conversion agian. I decided to add trim to it using Wave Raider components. All I have in so far is the cam. Im sure this has been posted multiple times before but I figured I would post how I did it anyway.
    The trim system from a Raider 1100 pretty much bolts right in except for the cam plate but its as simple as trimming off a portion of the plate that interfers with part of the hood, bending the mounting tab at the end and drilling a few holes.
    The hole locations are not critical but if you drill them too close to the cam wheel the bolts there is a curve on the underside of the hood that becomes a problem. I wouldnt recommend drilling the holes any closer to the cam wheel than I did. I used a 1/4" drill bit and 6mm bolts.
    Feb 2004
    Phoenix, AZ
    I also just recieved the conversion parts.
    I'm using extruded 3"x3" 0.25" 6061-T6 square tube to fabricate the conversion plates, 0.25" shorter Raahs mounts and washers, and GP760 midshaft.
    I will cut the tube end to end to make two c-channel plates, this way I can run the taller mounts vs. 3/8" shorter mounts and bar stock conversion plates.
    With any luck I will have it mocked up this weekend.
    Feb 2004
    Phoenix, AZ
    I installed the rear exhast and Raider 1100 water box. I still need to figure out a way to secure the water box but I think i will wait until the engine is installed to make sure the alignment is correct then just use some expanding foam to make a cradle for it.
    The back of the Blaster has a slight curve to it and the flange of the exhaust doesnt lay completely flat so I cut up one of the original exhaust tubes to make a gasket.
    I also installed the GP1200 gas tank. I had to lengthen the straps about 1.25" on the left side and 2" on the right side. I think it turned out ok considering it was my first time using a sewing machine. I used a tie down strap for the material and some high strenght thread my wife had.
    May 2011
    miami
    You should be able to rotate the exhaust outlet to fit flush and the tubing should be parallel to the hull. The exhaust outlet was designed for the blaster hull with the taper in mind.
