What color is a 1998 SXI Pro motor? - Page 2
Results 11 to 15 of 15
    Sep 2017
    Europe
    Re: What color is a 1998 SXI Pro motor?
    As from what I learned from the previous owner it was used for racing (not sure if true), but that kinda explains the fpp limited pipe on it, r&d grate, and that it was already over bored by 0.5mm, wsm pistons, new crank and oil pump delete. Would they gain anything by using that gray engine compared to the pro engine? Or they just blew up the teal one and replaced it with the first similar thing they found.
    Sep 2017
    Europe
    Another mind f**k is that the hull is hand laid fiberglass with a sticker infused in the resin saying it's made in 1998, featuring all the graphics and paint from that years sxi pro, in which case the vin # should say JS750C and not JS750B like mine does (correct me if i'm wrong) ... I doubt that it's a "european model" kind of a deal and that it's the reason for all the miss match... Seems to me that the previous owner did much more than just an engine swap...
    Top Dog bandit88's Avatar
    Green Bay WI
    Sounds like you have a SXI Pro that someone swapped in a 95 SXI motor and HIN
    -95 750SXI
    -90 TS650
    -91 300SX
    Green Bay WI
    Check the HIN under the battery and see if it matches.
    -95 750SXI
    -90 TS650
    -91 300SX
    SE MI
    The hin in the engine bay of a sxi pro is on the bulkhead behind the battery near the through hull bearing.
