Need Trailer for SXR-800
    PWCToday Newbie apexlocator's Avatar
    Sep 2009
    Eastern Panhandle of WV
    SXR takes 12in bunks and a very small PWC trailer. Any thoughts?
    2006 SXR-800
    PWCToday Guru Jim_ii's Avatar
    Re: Need Trailer for SXR-800
    I once used a bolt together Harbor Freight trailer kit with an SXi Pro. It was cheap and small. Not the best build quality but depending on how far you tow it might be fine. Good luck!
    I dream skis GlenT's Avatar
    Jul 2002
    Surprise, AZ via NorCal
    I've looked over a year for a stand-up trailer without luck. The Triton Wave is the smallest I could find, but it's $$$. The Karvan (also sold under Sea-Doo Move I) looks okay too. The challenge is finding a trailer where you can mount the bunks vertical. Most would require some sort of modification to the dropped cross members. Best bet is to find something used, like one of the small old school Zieman's.
    2004 Kawasaki SX-R
    2001 Kawasaki STX 1100 DI (GroupK Stage 1, STX-R rideplate, BH Sponsons)
    Top Dog aggrovated's Avatar
    Jul 2008
    Frozen Tundra, MN
    The Karavan bunks can be mounted at a little over 45 degree angle which works very well.
    Top Dog Bionic racing's Avatar
    Aug 2016
    Idaho/California
    My 92 long run stand up only trailer holds my SXR and square nose but it's tight
