Results 1 to 10 of 10
    Oct 2017
    Florida
    2
    Is there a TDR Waterbox option for 97 Waveblaster 2?
    Hey All,
    I've had a waveblaster II for quite some time now and thinking about changing waterbox to a TDR aftermarket. Only thing is I can't find one so I was wondering if getting one thats for the gp760 would be the best option??
    May 2011
    miami
    Re: Is there a TDR Waterbox option for 97 Waveblaster 2?
    Mar 2007
    Is Everything!
    Call Tony and ask, he’s a super cool Greek dude.
    May 2011
    miami
    Are you just trying to make it louder? There is a $20 way to do this.
    Oct 2017
    Florida
    2
    Quote Originally Posted by 2strokesmoke View Post
    I am trying to make it louder yes and I have actually been on that other website before, its definitely a good place to go. However, yeah how do you make it louder besides piping it?
    May 2011
    miami
    There is a engine cooling line that is connected to the exhaust outlet. If you remove it from the outlet, cap the nipped off. Then connect the cooling line to a over board pisser. Ski will sound the same in the water as it does on the trailer.
    May 2011
    miami
    Oh... I forgot. First remove the seat and unscrew and remove the battery bucket thing. Then you can access the line I'm referring to.
    Oct 2017
    Florida
    2
    Alrighty I'll get to that! Thanks again all!!
    May 2011
    miami
    Then one step further than that. Will cost you about $150. You can move the exhaust outlet to straight out the rear instead of the exhaust dumping in the pump area. My cousin's is set up like that with the stock water box. Sounds good. Like a piped ski
