Results 1 to 10 of 12
    Sep 2017
    Indiana
    Paint inside hull?
    My 550 has dark blue paint inside the hull and it's flaking off. It looks horrible. Is it common to have paint inside? My sxi doesn't. I'd like to remove it but it doesn't come off easily and I"m afraid of using some sort of chemical.
    Re: Paint inside hull?
    Somebody painted it. Carefully wrap engine/exhaust/etc with aluminum foil. Spray EZ off oven cleaner on blue paint. Wait 10-15 minutes, wash it all off.
    Sep 2015
    Northern Michigan
    Myself nice idea.
    Jun 2009
    iowa
    ok with that being said I pick up a 92 750sx and was wanting to give her a good cleaning sanding and a paint. are these skis jell coated or are they painted. also what can a person do to get the old crap out of the engine bay. the grease and grime. this ski hasn't ran for about 6 years.
    PWCToday.com Is My Home Away From Home Camasaki's Avatar
    Mar 2013
    Palm springs ca
    Gel coat.
    If it hasn't ran in 6 years I would personally yank motor to inspect everything and replace seals. You'll than have access to clean up the inside nicely.
    You can't drink all day, if you don't start in the morning.
    Jun 2009
    iowa
    Yes it’s already stripped. Now I’m trying to figure out how to restore the hull. Is the engine bay painted from factory. Any good vids on how to gel coat.
    Sep 2017
    Indiana
    Evidently they must have used oven paint because Easy Off didn't work. Any other suggestions? It comes off by scraping but slowly and there isn't a flat surface in the hull.
    Which easy off did you use? I should have specified yellow can original. The new low fume stuff won't work.
    Top Dog bandit88's Avatar
    Green Bay WI
    Kawi painted their painted with imron, they are not gelcoat.
    -95 750SXI
    -90 TS650
    -91 300SX
    Sep 2017
    Indiana
    Yep, yellow can, heavy duty Easy Off. It's not a "must have", it's just ugly. Half painted and dark looking.
