Totally forgot to order some when i placed order with SBT. What can i get from local auto parts store that will work? I have Autozone, parts plus and advance auto local to me.
Case sealant
Collapse
X
Re: Case sealant
Motoseal 1 Ultimate.http://www.facebook.com/twinlakesjetskirepair
Re: Case sealant
I like loctite 518- How many gerbils could a gerbil jammer jam if a gerbil jammer could jam gerbils?
"You build cheater motor's & still get smoked !!!!"
"Its not your fault. You just don't understand what you're talking about. "
Re: Case sealant
A dab of blue Loctite every nut or bolt.http://www.facebook.com/twinlakesjetskirepair
Re: Case sealant
Originally posted by kcr357 View PostI like loctite 518
Rotax must have had some brain-dead engineers when they specified Loctite 518 back in the day. They finally wised up and went to a silicone sealant for cases in 2001. One of the best reasons to ONLY use silicone these days is because you never know the history of an engine you are working on. If it ever has used silicone, then Loctite 518 will NEVER set properly on those case halves again.
A lot of "leaky inner seals" are misdiagnosed. What is happening is the 518 breaks down and the oil is leaking at the case halves.
